dupa
when changing belt should i use alcohol or sand paper to clean clutch wheels ?thanx
Use a WHITE scotch brite pad.
dupa
+ alcohol or just dry pad??duheme said:Use a WHITE scotch brite pad.
dry WHITE schotchbrite - make sure you only use the white kind.
Been using the green scotchbrite pads for 12 years.
green is alot rougher the white will not scratch up
