Groomer08
So as the title states, the bogey wheel mounts loosen up...
And the kicker?you cant just tighten it.
The mounts are such a soft casting, the rail eats it before you notice it.
With mount tightened, wheel sits on a 15 degree angle.
Rail seems fine, but the mount is missing a 1/4" of material.
Good news? Its a cheap part at 3.65
Oh, and the affected hyfax changes so easy i did it in 5 minutes...without using the reverse method!
this was front outside bogey clutch side.
