YamahaRider10
2010 Nytro MTX 153. Yoshi under tunnel, Heel Clicker Dragon Fly weights, Bender Helix stamped 09 NMTX, Bender White-Orange Secondary, HC Gray spring. Weights are Five washers in Heel, Center Empty, Tip Two washers and Over drive One washer. Engagment is 42-4400, Pulls hard and then feels like its hitting the rev limiter. Not sure if its a fuel issue or two many RPMS. Gauge is hard to read and also goes out at times. I don't have a fuel controller so not sure where to go from here. Thanks
akvector
you have alot of clutching mods. what is your wot rpms?
I would say try adding some weight to the tip. At this point small changes. It can be frustrating getting it dialed in.
beeze455
- Nov 23, 2010
- Bowdoinham, ME
- www.gopherdesign.com
Hold on -- "Gauge is hard to read and also goes out at times." ???
YamahaRider10
Yup. Hits limiter and flashes out then comes back on. Highest I have seen so far is 9100
YamahaRider10
That gray HC spring is like an inch + longer than the stocker. maybe I should go back to the stocker?
