can someone explain the low idle rattle in the clutch on my 04-warrior.i've heard this in other rx 1's.should i be concerned.
would you know the cause and repair if required.just rolled 11000 k
problem free.
its the reduction gearing, think about it, if the engine is turning 10k+ rpms, the track couldnt handle it. some riders turn up the idle rpm to 1600, it does help some, just get used to it. Its NOT the clutch.
