RealDeal
In everyones opinion which clutch weight is the best for building a clutch kit for a apex rtx . I just need somewhere to start. I have alot of helix's and springs.
Kråkan
I had supertips on the Vector last year. works great. Going to install the new 50g weighs on my Nytro. They have alot of adjustability.... heard that they work great on the Apex also...
Turk
Tech Advisor
I had great luck with 40/20 hammertimes & the secondary stock. 40/10,s would work also. Don,t be scared to use oem yamaha or dalton springs with these weights.
RealDeal
Where can I get a set of the hammer time weights
RealDeal
My brother has a set i'm going to try, what spring do recommend starting with, I have 192 studs. Also has anyone tried the new drag& fly ramps?
It all depends on what your trying to do.
Lake race,trail,top speed,all around.
RealDeal
all around but like to play on lakes and muck flats with buddies
Turk
Tech Advisor
If you have a set of 40/20,s try em empty with a p-g-p yammie primary spring. don,t touch the secondary. may not work for you but was sure fun in my 07 attak.
RealDeal
The ramps I ended up with where the 40/10's so I added a screw and washer to the middle and heel of the ramp empty in the tip with a o/p/o spring stock helix at 70 degrees. Pulled up to 10,200 from a dead stop, but when running at 50-70 mph then punching it , it would only pull to 9500. Was'nt back shifting. I'm going to either try a o/s/o or try a 51/37 helix . what do you think Turk?
Turk
Tech Advisor
You should run the weight empty with 3 gram bolt in heel with your o-s-o spring. I think it will be close.
