There are 8 or 10mm bolts on the backside of the secondary that are used to adjust the deflection of the belt by adding or removing washers. Those are the 86.4 in/lbs
Yes tighten the primary bolt to 85 ft/lbs then loosen it up and re torque to 43 ft/lbs
The cover on the primary clutch has 6 small bolts that are tightened to 10 ft/lbs.
