Does anyone know what size weights are in the motor clutch of 03 RX 1 vs 04 RX1 in grams also helix size and gearing? Or are they the same. Thinking with new ripsaw track it would not be the same. Would like to compare it to RX Warrior clutching set up. The new RX 1 and RX Warrior must be running a different combo. Due to the fact one has a longer track. I am trying to find out how they hold there peak rpms in the Rx1. Seeing it has a shorter track are they running heavier motor clutch weight or they running different springs or helix to hold peak rpms. (Later)
