Clutch weights for 400hp+
Full Power Performance has weights that can be loaded to 120 grams with an aggressive profile!
Any pictures of the Full Power weights ?Magnets or screws for weights?
I would need to take clutch apart for pix and I don't think they have pix on there web site. They have two mount locations on each side staggered so they don't load weight directly across from each other, basically four locations total from heel to tip? Large hex head screws of different length and material as well as washer's. I haven't had really any time with them yet so I can't give any feed back till next season.
Ok,thanks
I will keep looking for some photos and info.
I'am sure if you gave Justin a call at Full Power he could answer any questions and text you pix.
STM helped me with some 72g weights serie X.
How much difference will it be beetween x series and the standard supertip. Today i am running supertip standard 60g base weight, with 2 tungsten in tip, and 2 tungsten in middle. 10800 rpm at 18-19 psi. The x series is more agressive. Thinking 25-30 psi.
Some thoughts ?
Like KViper said,call Justin at Full Power and he will be able to fix you up with his weights.
