Clutch weights - non/rivets?
sledneck22
Sparta, WI
Has anyone used anything other than stock yamaha rivets in a stock clutch for weight? is there any way to use a small bolt and nut in comparable weights??? or has anyone used standard rivets from the hardware store or should these just be bought from yamaha?
Rivets from the dealer are your best bet. Never seen a hardware store carry a rivet that fits the weights. Nut and bolt would work as long as you use a good loctite to keep them in place and you have enuf clearence in the clutch
