Wakegod
I'm running the MPI stage 1 on my Apex. Currently hitting too many rpms even with my shockwave helix. I want to bring my rpms down about 6-800rpm to preserve the life of my blower. I've got some custom rivots that are about 4 grams heavier, which I've heard is approximately what I need.
Currently I have the stock rivot in the heel, then a heavy custom rivot in the middle, and the stock rivot on the tip.
Assuming I want to bring the r's down 4-600ish to start would it be better to put the heavy custom rivot in the heel or the tip of the weight?
Thanks, Rob
Thanks, Rob
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
You can bring your r's down by putting the weight in the tip ,however,it will change the ingagement r's . With the weight on the tip,it will also squeese the belt harder on top end and will tend to give you more MPH. Often I find that I need to split the weight from tip to heel to keep my clutch engagement where I want it.Hope this helps
You can also go to a primary sprin with less total force if you want to keep the same engagement
Wakegod
So putting the weight in the tip will increase my engagment rpm?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Agreed. Spring or pin weight,,it's like the same trade-off
jbsr
I've got the same problem with supertip weights.
The heel and the tip are both full. What does adding to the center do to engagement and peak rpm speed?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
I find that the center is neutral. It doesn't change ingagement much but changes rpm.
Clutching -- Where do I start?
Correct Air Fuel Ratios are a must before you can begin clutching.
Focus on the primary and getting your engine rpm right. Your combination of clutching should take you right to PEAK HP and create continuous acceleration from bottom to top. In the primary (drive) you'll increase or decrease the weight and or profile of the flyweights to achieve this. Lighter weights reduce "grip" or "squeeze" and raise the rpm. Heavier weights increase the "grip" or "squeeze" lowering rpm. Heel = bottom end, Middle = Mid-range, and Tip = top end. Make sure you're using the same profile of weight when you make changes or you'll end up chasing your tail. High profile weights apply force quicker and flat profile weights apply force slower. Large rollers tuck the weight into the weight pocket and decrease the weights leverage or initial force. Small rollers untuck the weights and increase the weights leverage or initial force. You want just enough "grip" or "squeeze" on the belt that it doesn't slip.
Once you have your rpm where you want it your next job is to get the combination to shift the way you want it to. That's the job of the secondary. The combination of spring and helix is what determines your rate of shift either up or back. The secondary spring directly equates to side-force or "grip" or "squeeze" on the belt. The idea is that the more side-force you have on the belt the less efficient it is because of belt drag. You want just enough "grip" or "squeeze" on the belt that it doesn't slip. Too much pre-load, side-force, and the clutch will back-shift too fast, put you in too low of a ratio, and overrev when you stab the throttle out of a corner. All rpm and no GO !!! Too little and it won't back-shift fast enough, it will react sluggishly, or bog out of the corner, or lose rpm while trying to maintain high speeds. For the climbers you'll lose rpm while climbing. If your shift rate is where you want it DO NOT use the secondary to adjust engine rpm. I've seen a lot people use an increase in the pre-load, side-force, of their secondary to bring up their engine rpm, myself included. You are shooting yourself in the foot !!!! Once you go past the balance point it will decrease the efficiency of transmission of power to the track while adversely affecting the ability of the secondary to keep the shift curve flat. Lastly, I'm a believer in running the lowest gearing possible and still make the mph you're looking for. Gearing is a great way to increase out of the hole acceleration (torque multiplier). Its less work for the clutches, engine, and they will both run cooler.
Common Pit-Falls: Clutches MUST be clean. Clutches MUST have the correct side-clearence, deflection, offset, and center-to-center. Bushings MUST be serviceable. Springs MUST be within tolerence. Belt MUST be cleaned before break-in and within tolerance after. If all of these conditions are met see below.
Only change ONE thing at a time. Take good notes, like snow condition, temp, elevation, terrain, what you changed, and the effect it had. The primary (drive) and the secondary (driven) will directly effect each other. Try not to over compensate one to "fix" the other, it's a BALANCE you're looking for.
Note:
What works for boondocking/hillclimbing will not work for drag racing and what works for drag racing will not work for boondocking/hillclimbing.
Under target rpm.
1. Too heavy primary (drive) weights.
2. Too low finish rate (drive) spring.
3. Too steep secondary (driven) helix angle.
4. Too low tension in secondary (driven) clutch.
5. Too tall gearing.
Over target rpm.
1. Too light primary (drive) weights.
2. Too high finish rate (drive) spring.
3. Too high tension in secondary (driven) clutch.
4. Too shallow secondary (driven) helix angle.
5. Too low gearing.
Note:
Under target rpm.
Over target rpm.
5. Too low gearing.
Wakegod
Clarification to my original post. I'm adding another heavy weight to either the tip or the heal. The middle is staying status quo with the heavy weight. Basically I'm adding 4 grams of weight. Ideally I'd like to keep the r's under 10k, I know I can make more power at 10,200-10,500, just don't want to stress my blower anymore than I need to.
I agree with what the others posted: If your secondary is shifting the way you want it to you will have to load-up the weights heavy in all three positions to knock it down 6-800rpm or run a lower finish rate in the primary.
