A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Yamaha Viper MTX 162" MCX Turbo 190
- Sundsvall
Im on 39/19 and a 2" challenger track.
MNBlizzard
A.Granath said:Im on 39/19 and a 2" challenger track.
Interesting...I was thinking my stock 20t would be too low.
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Sundsvall
Stock on mine where 21/39 (Europe gearing)
Got a top speed now somewhere around 95-100mph (enough for me)
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
2 tungsten heel ,3 washers mid and 3 tip . Ulmer H 46\39 y/p/y @70, 69 grams. I ran the supertips the only problem I had was the bushings wear quicker than any other weight I have used. The performance was good but not the durability. I ran HH 48gram base weight. 1/2 " allen arm. 5 grm tungsten 1 st hole 3 grm tungsten tip . Going from memory around 73 grams . Yamaha GWG 100x300 low engagement good finish. Ran the roller Rooster secondary 41/37 that shifts alot harder than a reg 41/37 with amazing backshift. I always likes the HH . Over the years I have ran alot of clutch kits. At the end of the day in my opinion you can't beat HH. I have alot of notes from my Nytro to help you out. I also have a turn key setup for sale in classifieds .
FLYBYU
He bought a used supertip weight from someone on here and it's missing to many tungsten's for it to make that. Also the weight kit is setup with the STM Yamaha retrofit pins so it can run A.C. weights which are all gouged up and the pins won't slide on the brass insert bushings. I sent Ulmer some emails to get me a whole clutch kit for it rather than trying to piece it together because this exactly what happens. I'm the one who's building this sled for him.
MNBlizzard
I now have the low elevation SC clutch kit for sale in the classifieds.
