Independent03
- Jan 28, 2008
I just got done redoing a bunch of things on my 2007 Attack. I stripped her down and just put it back together and now i'm getting a code 11? I looked in the list of codes and it says cylinder identification sensor. What could be the issue?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
The sensor is located between cylinders 2 and 3. First, make sure you have it connected properly.
If the sensor is connected correctly, you can do a sensor test to see if the sensor itself is bad.
Using a pocket tester, turn the key to on, take the positive end of the tester to the white/black wires, and the negative to the black/blue wire.
With the sensor on, you should read 4.8v or above, with the sensor off, you should read .8v or less.
