Code 43 2011 apex se help no start
mshabaz
15 below. Crank no start. Code 43 on screen. First time ever had an issue in the cold. Any help would be appreciated. I can hear the pump.
43 is a fuel system voltage code but it should be able to start and run. Can u get it inside to warm up??
I have it in garage right now. Hope it helps
Anyone have any problems w these starting in cold. And why would a fuel system voltage error come up?? Sure as heck was cranking strong. My good ol faithful 06 apex fired right up!!!
To expand on what sx7001 posted, Code 43 is Fuel System Voltage. The ECU is unable to monitor battery voltage & is detecting an open in the circuit. When this happens, the ECU fixes the battery voltage @ 12V to allow the sled to run. This code is not a disabling code, the sled should run. Two things to consider are the battery's not fully charged or there's a loose connection in the fuel system harness (bad relay??).
Mine was an unmaintained battery... Jumped it via car battery and the next weekend wired in a battery tender Jr.
No problems since!!!
