code 43 on 08 nytro
Fuel system voltage. Check your fuses/relays and your battery connections
I have had this code 3 times on my 2009 venture gt and several times on my 07 apex rtx, always seem to happen if I don't warm it up completely and then shut it off = code 43 won't start and cant here the fuel injection prime, let it sit for hours or get heat onto the sled code dissapears.
code 43
This code is for abnormal power to fuel pump or fuel injectors. The problem is with the fuel injection relay. It is located in the nose in a four relay rack on the left side of the steering post. The injection relay is the third from the front. $ 10.00 at the dealer for an updated version. Also, di-electric grease to keep moisture away from the terminals.
