Code 84
hey, ya i know that it means tors but how do i get rid of that
I sprayed some WD40 on the cables and on any moving carb parts, also tightened up the freeplay in the cable. Good Luck
ok thanks, ya it just comes on sometimes when your just moving slow
hey, i tried the the wd 40 on the throttle cable, and there doesnt seem to be any slack in the cable, i guess ill have to spray the carbs, did u spray inside on the flaps aswell ?
Did the TORS code come on after you made any changes to your sled? ... riser, throttle positioning, cable routing etc.
You stating there is no slack in the cable makes me think something else may have changed bringing on the code.
hey,i think that i have found the problem, the cable was over top of the risers wich was pulling on the cable when the bars were turned, but yes this did happened last year, before the risers were on. ill have to give it a try tomorrow and see if it is better.
