It long but here it is, Apex gt, big boy spring with revalve, lowered the front end with limiter strap up a hole like recommended, road all day with ohlins set to soft setting moving to medium a few times in rough stuff, felt much better with no bottoming, only downside is I felt the sled was raking and not getting the weight transfer needed, it used to pull the skis no the skis are planted, my control rod is set between min and middle, today I got my bergstrem 8 inch tripples, once I add them where should I set my control rod, I was thinks between middle and max? You guys are awesome as my switch from srx to apex is starting to come around.
