I picked up a 07 Attak GT and want to take the parts off it to make my 07 Attak a GT and the GT non GT. So a swap.
Is this a can do job ? or is the wiring and computer different to accept the change?
Ohlins shock and wiring to non GT is easy....plug and play as harness plug is up on top of the chaincase. Follow the online routing of the feed wire carefully as it breaks pretty easily....ask me I know!
The other way is going to be a bit trickier as the GT tunnel doesn't have the RA adjustor hole....you may need to work on that one!
