CPR turbo
Blue shadow
CANADA NL
Just got my cpr turbo up and running . :Rockon: Thanks Matt(blueByYou 2000) For all your help.Jeff makes a good looking kit ;)! Going to run up to 16 psi on c-12.Three stock head gaskets with a one gal fule tank up front to switch on a fly when needed. LaLaLa How much TY people as Jeff cpr turbo kit on with good results.THANKS :flag:
If you never have rode a boosted Rx1 AAHHHAAA you have no clue!! HANG ON!!! :):) 16PSI my my that is going to be SICK!!
Skydog
'How much TY people as Jeff cpr turbo kit on with good results.THANKS '
'que?
um......what?
I read it a buncha times, im losing something in the translation?
13 PSI and it is unreal fast!! I thought my 200HP T-cat was fast boy i had no clue. :Rockon: :4STroke: :yam:
Skydog ;)!
feetsbig ,I buy all my parts from Matt (the speed shop) He his a good person to talk too about the CPR turbo and will help you out in any way he can.There is a lot of people on this site that can tell you the same.Jeff is the person that builds these kits and he will help in any way he can.I am sure that powderlites can do the same for you ,but you allways go were there is lots of help when you need it most.I am sure you will make the right step by asking others first,good luck.
canada not alberta
Feetsbig said:
Hey Blue Shadow,being you are fromCanada,why would you buy SimmonsCPR,instead of Powderlites?Just curious
I didn't know you meant alberta you said canada advantage is a distributer.
