07 GT
I have a dumb question. Can you gap the NGK CR10EK spark plugs???
Thanks.
Thanks.
Ported Hornet
They come pre gapped.
Should you want to change it, you can... the gap the spark needs to jump is the same no matter what direction it is traveling.
Yamaha Man
Now when you guys put these plugs in, you just take the other ones out and put the CR10EK's in and go? The cables and everything fit, are fine and nothing needs to be modified?
Yamaha Man
Yamaha Man
Assuming you put caps on them, yes. They are just bolt on and go (although the procedure takes probably 30 minutes)
Yamaha Man
haha alright thanks!
rightarm
Yamaha Man said:Now when you guys put these plugs in, you just take the other ones out and put the CR10EK's in and go? The cables and everything fit, are fine and nothing needs to be modified?
Yamaha Man
Check the Gap it won't hurt,after removing coil & boot blow air down into cyl head so if there is any debris it get's blown out instead of ending up in your cyl when you remove your plug.Clean boot and apply di=eletric grease to prevent arching.
- 13K
