SlowPoke
- Mar 11, 2007
- upstate NY
- www.synthetic-oil-tech.com
Was messing with my sled and finally got around to install my NGK CR10EK's, Started her up and it ran for about 30 seconds then stalled, wouldn't restart, reinstalled the original CR8's and she starts right up and purrs like a kitten, Any idea's??
SharkAttak
did you put the cap's on the tip's of the plugs before installing?
SharkAttak
did you find out what happened?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
You have the triple which calls for 1 heat range higher than the 4 bangers. Those 10's will be 2 heat ranges colder for your sled.........
SlowPoke
- Mar 11, 2007
- upstate NY
mighty-so you are saying that I need to look for CR7EK's?
Do they make such an animal?
Sharkattack- I haven't gone anyfarther.
SharkAttak
SlowPoke said:mighty-so you are saying that I need to look for CR7EK's?
i would say the cr9ek's, the cr10ek's are for the 4-cylinder's
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
You want 1 heat range colder which would cr9ek's for your engine.
thinksnow
I am running the CR9EK in my '03 TRX-1. Is that the wrong plug???? On the blet guard it says to run CR9E. What's right?
