Cessna180k
Hello All!
I just bought some Curve's they should be in showing up at the house soon. I have a 04 RX1 LE 121 track. Does anyone have any set up tips for me? Limiter Strap settings or center shock preload settings? or other.
Curve Industries
TY Advertiser
- Jan 20, 2008
- Waterville, NY
- www.curveindustries.com
Hey Cessna! We recommend bolting on and going for a ride first. You may be tickled pink without changing a thing. If not, your biggest concern should be ride height adjustments. You'll typically need to lower the front and increase preload on your front skid shock to do so. Limiting straps are kind of a last resort.
Very Important:
CHECK YOUR TOE! You'll want 3/8" total toe out on this machine. You can measure off the mounting structures just as they taper into the ski to pull your distances.
Call us with questions!
- Sean
www.CurveIndustries.com
www.GoProSchools.com
Very Important:
- Sean
Cessna180k
Thanks! Can't wait to try them!
and make shure your a-arm bushings are in spec. learned that the hard way on mine, love the skis though!
Cessna180k
Should be ok in that area. Just did them in the summer.
Curve Industries
TY Advertiser
- Jan 20, 2008
- Waterville, NY
I forgot to mention - check slop. Get a block of wood and jack under the belly and pick the skis off the ground. Go around and try to wiggle with your hand the spindle, a-arms, tie rods etc. You want to keep that front end toight like a toigah! (voice of Goldmember)
- Sean
- Sean
Cessna180k
Thanks Sean
All is new in the front end. can't wait to try them out!
