monker
What's the performance difference between the dalton R helixs and regular helixs. According to their website, the R's have a quick initial angle, then act pretty much as a straight angle helix. How does this affect performance? What are the pros and cons of each?
Thanks.
Thanks.
monker
anybody??
Buckeye
- Lakes Region, NH
This is not a progressive helix. It is 2 angles. For example, a 54r46 starts with a 54 angle initially and switches to a 46 angle about a third of the way into the shift out. A progressive will start at the higher angle and gradually go through the degress as it shifts to the final degree.
monker
are there any advantages to using or not using the R helixs?
black john
helx
i am running those helxs they work super with the steep angle at the start it laods the moter to take advantage of he torqe curve i.e a better hole shot with better hook up this is another old racers trick right out of the an old race race manual. note that the steeper the angle i ran the better it worked. i even switched to a green secondery spring to make it shift harder. i had to do some thing ti out pull my strong running mach z buddys and it worked it gave me about 3 lenths out of the hole with the stk track 8)
