monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- Does anyone have have some hints or tricks about using a Digital Camera in cold weather conditions? Zero and below ... with wind chill.
- Santa brought me a Canon Powershot sx210is and I can't get the damn thing to stay on when I remove it from my coat to take pics. :banghead:
- I used to have a Panasonic Lumix which was fine in the cold, but this new beast shuts off just as soon as I turn it on.
- I'm thinking it's the battery, but not 100% sure.
- What's everyone doing with their cameras?
- All help is appreciated! :cheers:
i also have a canon and it is hard on batteries,in the cold it shuts off on me also,but they are 1 tough camera,mine is beat up pretty bad and still works like a charm,1 trick,use lithium batteries,expensive but last alot longer
monte1214
- Apr 20, 2005
- Durham Region, ON
- Thanks!
- I'll look @ the lithium Ion batteries,
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Lithium is the ticket! I use them year round now just so I don't have to worry about having dead batteries because i forgot to re-charge.
johnketch
keep the batteries WARM , even if you have to take them out and put them in your pants pocket.
I cary two sets.
I cary two sets.
quebec#1
lithium batteries are the way to go and i also store the camera in my winshield bag.
If you are planning on using the camera alot one day snowmobiling when it is cold I would put the camera in a thick sock, put it in a pocket that is inside your jacket that is close to your body. If you need more throw a little heat pack in that pocket with it. That being said Lithium batteries will help.
monte1214
- Apr 20, 2005
- Durham Region, ON
- The Lithium battery made a bit of difference, but I've bought some of those "shake & bake handwarmers" to put in my pocket for the next time out.
inferno
i owned a powershot, it would turn off after taking it out of my jacket because of the moisture in my pocket. the camera has a safety feature to prevent it from powering on when the is moisture present. try keeping it in a ziploc bag. worked for me.
monte1214
- Apr 20, 2005
- Durham Region, ON
inferno said:i owned a powershot, it would turn off after taking it out of my jacket because of the moisture in my pocket. the camera has a safety feature to prevent it from powering on when the is moisture present. try keeping it in a ziploc bag. worked for me.
- Never thought it'd be that???
- I'll try it.
- Heading out later this week.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
I wrap mine up in a towel and put in the back storage area where it stays warm while you are riding-- that is a heated compartment. Just put your bare hand in there on a trail stop, warm and dry. Just make sure there is enough stuff in there to keep it from bouncing around.
RIGIDONE
I use two of those shake and bake handwarmer packets in my backpack with my camera inside if a winter hat.. dont have any issues.. but it rarely gets below zero, we r usually riding around 20F.
