dolly for apex
I have a home made set with HD wheels that will roll on my crappy driveway:beer:
To the OP I wouldn't get that one you listed or any similar to that, save your self the time and money and get the good ones with the big wheels I think they are like 300 bucks or maybe 400 but will be worth it. I bought one like the one you posted and at the time i had my 2010 mxz 800 and it would hardly get the skis and track off the ground, i had to cut the main arms on an angle and weld it back together so that it had enough arc angle to pick the damn sled up. Those things are made for the older style sleds from the 90's and 2000's and that is why it wouldn't pick up my 800. Also those things just bolt together and are very flimsy in my opinion and it seems like it had a hard enough time moving my feather light mxz 800, I couldn't imagine lifting a hefty sled like our Ape's with one.
the cart or the lady lol
EZ move usually has some show specials if you buy new. They will be at Haydays I would bet. The larger "horseshoe" carts work, but where do you put the thing when not using it? My EZ move breaks down and hangs flat on the wall. There is a big wheel kit available if you take it off concrete. Otherwise, on concrete you can adjust the height easily.
I used to have to adjust it when I had both trailing arm and rider forward sleds. Now it stays up high for the phazer and apex's The apex is a tank, and will make any cart creak and moan a bit.
Good luck
