Dupont slides uneven wear
Age
55
North Bay
Canada
2016 VK Pro II
First season with Dupont sliders and just noticed at the rear of the sliders they are half the thickness as at the front of machine. What suspension adjustments can I do to create even wear? Would tightening limiter strap create more even wear? Machine does bottom out on moguls so I
plan on increasing rear suspension settings too. Any ideas or suggestions are welcome.
Thanks,
Ned
I agree that tightening the strap would likely increase wear at the rear. By the same logic then why not try letting it out to let the front of the skid down to take more of the load. That might help with your bottoming out too.
do not bother. that is how they wear. bros rx war and my dads sx venture with them are both worn the same way. where the wear is is after where the vespl inserts stop and the plastic is softer than normal slider plastic. as long as they are not worn below min thickness i would leave them alone.
