Dr Ecto
- Jan 22, 2014
Anybody on here using an Eazymove sled dolly to move their Nytro around? I need to move sled in and out of garage into the yard. Just not sure if it will be ok lifting on all that plastic and will lift the sled high enough. Thanks.
[web]http://www.eazymovecarts.com/ezmove/[/web]
dab102999
petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
Easymove works well with Nytro. May want a big wheel kit if going outside.
Dr Ecto
- Jan 22, 2014
Thanks a bunch. Definitely going with big wheels too.
mdkuni
Great product, works great on the Nytro. Definitely get the big wheel kit as mentioned.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
I don't have any problems with just the small wheels (garage to paved driveway to lawn) it rolled ok.
Wife's Z1 turbo 'Cat is heavier but still manages.
For the price & simplicity of a Big wheel kit, make it from Harbor Freight stuff.
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Dr Ecto said:Thanks a bunch. Definitely going with big wheels too.
Before going with the big wheels, make sure they will fit under your sled in front of the track, and behind the skis.
mdkuni
#1APEXRIDER said:Dr Ecto said:Thanks a bunch. Definitely going with big wheels too.
The wheels are added after you slide the dolly into place and stick out to the side. I can't imagine there being an issue on any sled.
Dr Ecto
- Jan 22, 2014
Should be here tomorrow. The $40 shipping seems high but I have to do something different. Took me 45 mins to move the Nytro into the garage the other day. I will report back after I move it for the first time.
Dr Ecto
- Jan 22, 2014
Moved the sled yesterday with the eazymove. Definitely easier than my old little castor wheeled ski dollies. It was still a 2 man job to move it across a little hard packed snow and up over the lip into the garage.
alaliberty
- Jan 9, 2010
- NW Wisconsin
- 2009 Yamaha Nytro
- NW Wisconsin
Love my Easymove Sled Dolly. Gets the sled off the ground so the shocks are not compressed and makes it really easy to move. I did put a strip of angle iron to reinforce the wood since the Nytro bowed it.
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Dr Ecto, Do you have the big wheels, would it still be a two man job if you had the big wheel option? Second question, I believe Eazymove's big wheels are 10 inches, is there room to use 15 or 16 inch wheelbarrow tires or are they too high to install(I suspect the axle hole would have to be 8 inches off the ground at some point, to get the axle in?)
Dr Ecto
- Jan 22, 2014
I do have the big wheel kit. I think if I would of have had more room to get some speed built up I could of maybe popped it over the ledge of the garage floor. Next time I will load up further down the driveway and give that a try. I don't think you would be able to put any bigger wheels on it, due to the way it lifts the sled.
mdkuni
Dr Ecto said:I do have the big wheel kit. I think if I would of have had more room to get some speed built up I could of maybe popped it over the ledge of the garage floor. Next time I will load up further down the driveway and give that a try. I don't think you would be able to put any bigger wheels on it, due to the way it lifts the sled.
Little trick I use to get it over the garage floor lip, approach the garage so one wheel hits the lip at a 45 degree angle. Once one wheel is up take the same 45 degree angle approach with the second wheel. You still need some momentum but this works much easier. I fought with trying to get both wheels over at once for several years and it was always a pain until I started doing this. Pops up real easy this way.
