Glock30
- Apr 14, 2004
Anyone know of an EFI kit that is available for my 3cyl. RS Venture engine?
Thanks in advance.
Thanks in advance.
zigyqhouse1270
- Dec 14, 2005
i dont know about the EFI but was woundering if you had the wheel problem on your sled and what your fix was.
Glock30
- Apr 14, 2004
I had excessive hyfax wear resulting in loud track noise.
Replaced hyfax.
Replaced stock wheels with 5mm oversized rubberized wheels.
No/little hyfax wear
No/Little track noise.
Hope this helps.
Replaced hyfax.
Hope this helps.
zigyqhouse1270
- Dec 14, 2005
did you replace all the stock wheels or just the bogey wheels in the center of the suspension if you have the part # name brand that would be great
Glock30
- Apr 14, 2004
Replaced all of the wheels in the center(6?). No part number as they were made up by my dealer. Some aluminum spacer machining required for these wheels as they have wider removeable bearings. The +5mm dia. seems to hold the track away from the hyfax better and reduces/eliminates the heavy wear.
Rev-It-Up Yamaha
207-864-2452
Rev-It-Up Yamaha
207-864-2452
Tork
Glock30 said:Anyone know of an EFI kit that is available for my 3cyl. RS Venture engine?
Thanks in advance.
Yamaha took their FJR 1300 motorcycle engine, took off the EFI and one cylinder and made the RS motor. No kits available that I have heard of and the motorcycle parts would be a big job to adapt, mainly because power pulses are 120 degrees on the 4 cyl and 180 deg for the 3 cyl. Plus you would need to come up with cold weather fuel mapping.
Glock30
- Apr 14, 2004
Thanks for the reply Tork, but I am looking more for a bolt on system. :ORC Guess I'll have to be patient or buy an Attak.
jehu
Stop being so cheap and buy an Attak!!
Jim
Jim
Glock30
- Apr 14, 2004
All:
Please pay no attention to jehu.
He has been stalking me on the forums posing as my brother who is reponsible for getting me into this hobby.
alaskanbowtie
TORK, is right on, I've looked high AND low for an efi kit
Tork is quite knowledgable when it comes to these engines and is correct, know one makes an efi kit for this engine, know one!!! i've looked for months want to do the same with some other mods but it's simnply not available and a custom built kit is around 2200.00, I hope that someone will eventually come out with one, this is highly unlikely though since know one made one for the mighty RX-1.
