peakperf
- Oct 1, 2003
- Hayward Wisconsin
- 1972 GP292, 1972 GP433, 1972 GP643, 2003 RX1, 2007 Phazer GT
With all of the K&N and jetting talk, I was considering installing an EGT gauge on my RX1. I'm confused on what numbers do you look for? On a 2 stroke 1100 to 1300 degrees is considered optimum jettting. Do you jet the same way for 4 strokes?
Scott
Scott
spray25
Why not install an air/furl gauge instead?
TURBO TIME
spray is right, an air/fuel ratio gauge is the only way to go, i have one on my turbo and it works perfectly, it will tell you if you are lean, rich, or right on the money at any throttle position.
looking4speed
I put an oxygen sensor on mine. I would recomend the 4 wire to make sure you get accurate readings in the cold temps. Mine is used with n2o system to shut off if readings are to high or low.
peakperf
- Oct 1, 2003
- Hayward Wisconsin
Looking4speed,
Where do you buy one of those?
Scott
Scott
looking4speed
Depends on what you are looking for the oxygen sensor is a standard 4 wire GM part the n2o controller is fron Schnitz Racing it comes with digital readout that I mounted on dash.
- 6K
