YaMon
Does anybody make a kit or exhaust to dump to the track. I want to be able to use the tunnel extension on my Vector Mtn to carry stuff. The way I see it, Yamaha made the extension rack totally useless. Any ideas that don't require 4 days of work?
impalapower
Not sure if anyone makes an exhaust/tunnel kit. KBXSRX did the thing you are talking about. Contact him.
YaMon
Thanks Kevin, I saw that he did it, but it looks like it took a lot of time. I was hoping that someone had a kit, or some way of diverting the exhaust down away from the tunnel extension.
LazyBastard
Aside from the fact that he completely replaced the whole tunnel (for reasons other than the exhaust), I seriously doubt that what he did with the exhaust was all that much work.
If you just want to get the exhaust down under the track, buy a couple of those kind of cans from an auto store (make sure they're stainless), cut the pipes, weld the new cans on pointing down.
You would probably also want to block off the hole under the seat so that snow doesn't fill it up.... a piece of sheet aluminum riveted in there should suffice.
If you don't even want cans, just weld elbows on the pipes.
