exhaust
zquick1
Ludington MI
Has any one herd the ght-r-done exhaust how loud is it.Compared to stock and any gains
PM mnmsnowbeast he had one and said it was loud and he felt that his sled lost HP with the Hauck set-up. He also removed his.
pipe was too loud, it hung down 1/2 inch lower than the stock one and pat wouldn't fix it. Before pipe was damaged sled ran same rpm before and after.
I had the pipe fixed and rewelded 1/2 inch higher under the tank.
and if your wondering I'm running the stocker again.
Plus you have to repack these every year or 2.
Go with WhiteKnuckle or Excell, both great companies that will take care of you.
And to be honest, stock is lighter than the RX pipe was and stock makes great HP. Plus states like Wisconsin have new noise laws. These are additionally reasons to stick with the 2 I mentioned above because the noise level is reasonable.
my opinion, leave the stock exhaust and do the ram-air, it wakes the exhaust right up, loud enough
2-3 h.p. gain
ONROF;
What size studs did you have on your track. Seems like you had way longer than recommended....
Installing the GET R Done this weekend...
TotallyNytro said:
ONROF;
1.45's and 3900 miles on the stock muffler without a problem.
When I called Hauck looking for info they said not to stud 4 inch's down the center or it would damage the exhaust. This is a problem for me because I already have my track studded, and question how many scratches would be lost.
