tjc
Has anyone seen how far a stock nytro can go (stock motor, stock injectors)?
What about with a fuel pump upgrade and 1:1 regulator.
From what I see it is 6 PSI boost with stock injectors and pump at sea-level.
Would it work at 9 PSI boost with the upgraded fuel pump, 1:1 Regulator, stock injectors, stock timing, and stock motor?
I was hoping for close to 10 PSI for trail.
