I just purchased a Cobra track for my SE. Was thinking of using extroverts during the swap. Are there any rail clearence issues if I use the same tooth as stock or will the rails need to be trimmed back?
I just put the 9 tooth extros on my xtx, when it's sitting on the floor it has about 2" of clearence to the rail tips and I think it won't get any closer than about an inch. If all the suspension did when it moved through its arc was go up it would hit but with the length and angle of the front arm it looks like it should be moving back at the same time its going up. If it is too close I don't think it would be hard to buzz a half inch off though.
