I keep seeing threads on this topic pop up all over but most of them here.
Most of these sleds have the proper 3 amp circuit already wired and the
plug sitting there and waiting, and or they have a cigarette lighter style you can tap off of already plugged into it.
Sumitomo connectors
http://www.easternbeaver.com/Main/Elec_ ... sm-mt.html
RCA Snowmobile plug from Marshall Snow
http://www.powersportsnetwork.com/enthu ... egoryCode=
My personal preference, I ditch the square housing. Available in red black and blue.
http://www.redco.com/shopexd.asp?id=707
The rubber caps I use:
http://www.redco.com/shopexd.asp?id=1657
Hope this helps. Your plug already has the other side there used as a
cap. You can just order the pins. But it's all very cheap anyway.
When the lighter plug is there I pull the pins, slide the oring seals back
on the wires and solder new wires onto the same pins for my rca plug.
Then I use a sealer to cap the wires at the plug. Keep it small or you won't
get the pin connector back in its housing.
An Apex setup with existing lighter plug and the Marshal Snow. And below that a Phazer with the RCA plug and cap.
Sumitomo connectors
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Nice write up/idea!
