fox float loosing air?
Dirtbikekid1998
Maine
2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I checked my front floats on my ltx se and the right side is always at 65 every time i check them and the left always drops to around 50 in a couple days. i have herd to just replace the valve where you screw on the pump, where do i get one and how do i change it?
It is just a schraeder valve. You can get a tool and inserts at any auto store. I would first pull out the insert and make sure its clean and reinsert it. If it still leaks, then replace it.
