Fox Floats question
vicman
Auburn ME.
Will it hurt anything if all the air is let out of my shocks at radar runs to suck the front end down all the way? Wondering if running these shock without air in them will cause issues. This is my first sled with Fox Floats.
I can't give you a technical answer, but I would think running them completely empty wouldn't be good for the shock seals. I've run my with as little as 10psi for drags, and the front end sits as low as I want it to..
floats
You dont want run your floats empty it will damage them. You can make straps out of limiter strap material to shorten the shocks and still run air in them or even easier a pair of srx shocks lowers the apex real good.
