The terms *hardest* and *softest* are not applicable to FRA. FRA = "Full RATE Adjuster". Putting the FRA on maximum means that the spring pressure will build *faster* than with the FRA on a lower setting.
FRA adjusts BOTH the spring rate AND dampening
charcteristics of the rear suspension. This means that the terms harder and softer do apply --- see page 8.24 of operators manual, and the sticker on your belt guard.
Maximun FRA means harder rear set up.
