Frame protrusion rubbing on coolant line!
Red Rocket
Ontario, Canada
Canada
2023 Yamaha Sidewinder LTX DX
Hi guys
Just a heads up to everyone that while doing some routine bearing maintenance I noticed behind the secondary clutch that the sheet metal from the bulkhead had been rubbing on the main coolant line and had almost worn right through! This could have been a bad situation obviously if I hadn’t noticed it when I did. I removed the round protrusion with a grinder and all is well but everyone should check theirs as well.
