SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
Seems like my front end of my 2009 xtx which had the front shocks rebuilt bottoms out on rolling bumps. Is this normal? Never had this issue on my 06 attak. It seems to slam into the face of a high side of a bump. Any ideas or adjustments I need to make?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Gytr shocks or floats?
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
GytrGytr shocks or floats?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
How does it ride over stutters? You can either add preload to front springs 1/4" at a time or add compression with the clicker on the resivoir
SnowBandit
- Jan 31, 2004
- NH
- 2009 Nytro xtx
We never got enough snow last year to have stutters and this my second season on this sled. I will turn the pre-load up a little and swe if that helps.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Check this thread out might help. http://ty4stroke.com/threads/tech-tip-adjusting-gytr-dual-clicker-shocks.104603/
Pete
Pete
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
What's your weight and what's the rear set at? If your to stiff in the rear it will bury the nose also....
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Make the front stiffer (shocks) Lower the rear ride height.
