tapp1
Ordered oilites and UP Bushman's kit. Hoping to eliminate this (ski bolt was loose from hacking up the spacers from pilots).
[video width=560 height=315]http://www.youtube.com/v/ey7khBV6wCA[/video]
Does this need balljoints too?
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
cant tell if it needs ball joints from the vid. def needs oilite bushings in the control arms and ski bushings. if you pull up on the spindle is thier any movement of the ball inside the joint. That thing mustve been scary to ride!! GL with the replacements
Supa Dexta
Yeah there's so much play in the bushings its hard to tell. .Def gonna feel better to get that tightened up though!
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
I did the same thing last month lol and mine was just as bad.
I did the oilite bushings in the arms and also did a custom ski bolt bushing setup (similar to UP Bushmans.)
My ball joints have a bit of play but things are tight enough for me right now. I was too cheap to throw another 200+ bucks towards ball joints.
You should be happy with just those 2 upgrades. Be sure to loctite all the bolts in the subframe on re-assembly.
dukemerc
- Dec 7, 2012
i just put the pilot skis on my 08,did they work for you? i did my own machining on the ski bushings everything is tight there but i see from your video the play in your upper a arm the bushings are shot,i only got about 400 miles on my new ones last year and i have the same play,im thinking about trying them new a arms from hygear at least they have a grease fitting in them ...
tapp1
dukemerc said:i just put the pilot skis on my 08,did they work for you? i did my own machining on the ski bushings everything is tight there but i see from your video the play in your upper a arm the bushings are shot,i only got about 400 miles on my new ones last year and i have the same play,im thinking about trying them new a arms from hygear at least they have a grease fitting in them ...
They stopped the darting, but I had a problem with them pushing in loose snow. So I switched back to the stock skis with dual runners.
sleddingfarmer
How many miles on that sled in the video?
I just did my old nytro the other week, it had 5200 miles on all the original parts. Oilite a-arm bushings, ball joints (oem) and Bushman's kit. The ball joints were definitely loose...but could have probably made it another season. I didn't want to take it all back apart in the middle of the season if we ended up with a 4k mile season tho.
Its sooooo tight now, I didn't know a front end could get so tight!
Radar22
Looks to me like just busings!
tapp1
sleddingfarmer said:How many miles on that sled in the video?
the sled has roughly 2500 miles on it, I do believe.
sleddingfarmer
You'll be able to tell if the ball joints are wore easier after you remove the a-arms. But I would think you could make it closer to 5k pretty easy. Unless those 08 ball joints are more junky than my 09s.
Supa Dexta
08s were more junky - And with that, Canadians did you get free replacements?
And was it a one time thing?
I've read that they were improved each year, up until 2010 atleast (old thread)
If I'm going to replace mine, what year ball joints should I ask for, that fit an 08 and last the longest?
