I am thinking of getting a Garmin Rino 110 with the 2-way radio built in. Has anyone used this or any other Garmin GPS radio set up. I have read that other radios like Talkabouts do not work well due to ignition interference.
I use a Rhino 520 and 2 other I ride with have 530's. The radios work fine when the sled is running. We have them mounted on Ram mounts on the block risors. You can hear the "beep" when someone keys another radio even while riding. You will need to stop though to be understood. Sending out your location to others is a great feature. If you can afford it go with the color screen, it is much easier to see then the B&W.
