Garrett gt2860rs vs. gt2871?
sledfvr
Plains, Montana
Just wondering how these turbos compare in lag time, power per pound of boost etc. Does the 2871 have much over on the 2860? Just curious for when I wear out my 2860.
What kind of Riding do you do?
What boost level do you want to run?
Who's kit is it based on?
What do you run for exhaust?
Comparing the 2 the 2871 will only be slightly slower to spool because of the larger compressor wheel.
They Share the same Exhaust housing and wheel, the Compressor will support 430 HP
Ted.
Its for mountain riding. On a bender rear mount. Usually run between 14 and 18 psi, sometimes up to 20.
The 2871 does have a little more lag. That was my main question. I saw on another post that 300hp and over you think should have a 3" pipe. This makes sense to me... I'll check and see what it has on it now.
Thanks Ted
