Cfpdscott
- Feb 23, 2016
- Illinois
- 2016 Yamaha viper Rtx-se
Anyone that's running gates belt have a clunky shift, especially going from reverse to forward? I switched from the 8dn to a gates 8jp equivalent and now my sled is very clunky when shifting. I've played with belt deflection I have the osp adjuster and even with the treads even with the secondary it's still clunky. Switched bake to t 8dn to test and it was quiet again
To me a clunky shift sounds like a belt deflection issue. Sounds a little snug.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Not familiar with the problem you are describing but just wondering if there is a possibility that the clunky shifting is being caused by your chain in the chaincase being too loose?
Have you checked the chain adjuster/tension lately?
Cfpdscott
- Feb 23, 2016
- Illinois
Yep just readjusted the chain. 1 1/2 turns out.
Rodney
- Nov 18, 2015
- Belle Ewart Ontario
- 2015 rtx se
I have the same setup ,and no problems with mine!!
mckay_06
- Mar 23, 2011
- Saskatoon, SK
- 2014 Yamaha Viper XTX
Sure you don't have a broken primary spring? I had the same problem and that is what it was.
