F7
- Jan 30, 2007
Guys I just bought this sled always had stock polaris or cat sleds nothing fast.This sled freaks me out.Anyways what gearing is in the apex.The new home for it is at about 1200ft sea level with all lake running finding out I am running out of gear quick.Does any one have a recommendation.Also is there sometimes a problem with the throttle safety switch I found that if I hold the throttle the wrong way I had a hard time getting it past 6 grand
sledheadgeorge
What kind of turbo you got on it? What boost you running? You can pull a 25 top gear easy and gain more top end.
F7
- Jan 30, 2007
It is a mc express running 12psi.Any tips in the throttle switch
sledheadgeorge
Check your throttle cable.
TurboJamie
I run 25/38.
