apex55
Spent the weekend getting the 06 Apex ER ready.
Changed the stator sensor.
New Speedo sensor.
Oil change.
Trapped the mice that built a nest under the seat on the fuel pump. They chewed up the plastic clamp that secures the fuel line.
Greased the mono shock frame.
Pulled off all the wheels and will regrease this week.
Grease the Speedo bearing and the secondary clutch bearing.
Need to bring the cover to have the zipper pocket repaired from the formentioned mice issue.
Need to renew the registration and get my early trail
pass and just wait for snow.
Track will need to
be replaced. Going to try for 1 more season.
New Speedo sensor.
Oil change.
Track will need to
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Check to see if shocks need rebuild.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you forgot to add a beer between each one of the steps...
Check gear chain adjustment and or change oil down there
