Grease nipples
Aside from the grease nipples there are areas in the skid that do not see grease unless you add it by taking apart. There are needle bearings in the shock eye and transfer rod ends , and some other plastic bushings that should be looked at periodically depending on suspension type. Front A arms, ski pivot collars and bulkhead bushings come to mind as well.
