Grizz 660 - Diff Questions ?
vectorboy
Calgary, Alberta
Does the Grizz 660 have a limited slip rear end ? I am trying to figure out a friends Grizz. He says only one of the back tires is spinning not both like they usually do, so he says. I jacked the ATV up and with the quad in gear both tires are locked solid. Any ideas ?
wow dood if only one tire is spinning when he gives it gas then it's got to be an axle issue....the rear diff on the grizz is locked....hope he didn't break and axle or screw up a CV.....it's quite expensive
