Grizzly Wheel Hub
deerguy
Hey all!
I am trying to replace the front, left cv shaft on my 01 grizzly. I know this shouldn't be that hard of a project, but I am having a hell of a time. I can't seem to get the wheel hub off. I don't see anything holding it on. I've tried hooking a jaw puller to it and its starting to bend the hub itself.
Thanks in advance for any advice.
-Mark
I'm assuming you took off the rubber cap and removed the big axel nut. If you did, what I do is put pressure on the puller pulling on the hub and then hit the end of the puller with a hammer. Usually it's enough to pop the hub off.
Thanks. Its off. I beat on the half shaft and it came off. It was rusted on pretty good.
