bluesman
I would appreciate reccomendations for gauntlets that people have installed on their Viper that allow unencumbered access to controls and that stay secure. Not interested in dumbo ears on plastic hand guards. Thanks
Robinmaine
I use my AC gauntlets. They are very warm. Easy slid on and off.I would appreciate reccomendations for gauntlets that people have installed on their Viper that allow unencumbered access to controls and that stay secure. Not interested in dumbo ears on plastic hand guards. Thanks
Sent from my SM-T817R4 using Tapatalk
bluesman
Do they interfere with using the hooks on the handlbars?
rbell14
I have very inexpensive gauntlets on mine. They merely velcro are pound the handle bars on the one end. Works great, easy access and does not interfere with any of my controls. I barely use hand warmers and only wear thin gloves.
Mine are from moose products. They have larger openings to get hands in and out quickly.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
For me Cold Guards are the ticket.
They block all the wind, yet provide easy access controls and bars.
No more cold hand period.
x2 on the Coldguards. Easy to put on and off, fit around most hand guards and lay flat and take up minimal space If if you store them in your sled bag
Will cold guards fit around the Yamaha hand guards...like on a Nytro?
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Powermadd guantlet s on my wife's viper. She loves them and won't ride without them. Easy access to controls. You do have to run the handguards with them as that's what they mount to.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
JAZZ04RX1
Frozen what version do have the standard or the deluxe? Also looks like you have a bracket of some sort that I do not see on the website. I like these and want to make sure I get all the right parts.For me Cold Guards are the ticket.
Yamacat21
I put the Yamaha hand guards on and bought the Arctic cat extension kit, works great
Robinmaine
Sorry for the late reply been on the road. Yes you can still use the hooks, plenty of room inside.Do they interfere with using the hooks on the handlbars?
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Mine are the deluxe hook grip. Only difference, standard vs deluxe, is the colored piping. Many colors to choose from.
http://coldguards.com/index.html
Be aware that the Cold Guards are not a solid, bolt on, application. The Velcro, with the anti-skid material, holds them pretty good. But they still will move a little. Also, the plastic tube, that holds them open, is not installed for shipping purposes. You'll have to fish it in. Be patient and don't rush it. Takes a little fiddling, but very worth it.
Here's the whole story originally sent to Bluesman via PM................................
The Cold Guards are fairly stable with the Velcro straps provided. I made them even more stable with the Arctic Cat nylon hand guard mounts since I leave them on all the time.
I pierced the Cold Guard, and used a small automotive push fastener to secure.
I used a small dab of super glue to secure the fastener to the Cold Guard and seal the edges that I pierced.
And there you go.
The parking brake can not be accessed with the Cold Guards installed. However I never really tried to make it accessible. Not sure what the brake is for other than burning belts when you forget to take it off!
I have not had cold hands since these were installed.
They are flexible enough to stand up at road crossings. They flex back once you sit down.
This entire set up will run about $85.00 when it's all said and done if I recall. Worth every penny.
I just bought a second set for my back up sled and my Fat Tire bike and my back up sled.
These will be mounted solely with the Velcro straps, which are very adequate.
Hope this helps.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I hate to say it but Ski Doo has an awesome set I put on my dates sled. They are Velcro on and off and have a push pin on the end that makes them rigid. There is also clear windows on the top to allow you to see the controls. One just has to use a little black paint to change out the logo . They are fur lined inside and even with fairly bulky gloves they work very well.
JAZZ04RX1
Thanks Frozen for the detailed reply and part numbers for the brackets. Nice work!! I will be duplicating that setup on my Viper ASAP!!!Mine are the deluxe hook grip. Only difference, standard vs deluxe, is the colored piping. Many colors to choose from.
And there you go.
Hope this helps.
