welterracer
Im thinking about adding some 45degree hooks!
Is anyone currently using them?
Will they fit under the Yamaha cover?
Do they seem to help with cornering?
Ive had them on the last three sleds and would not ride with out them. I don't use covers, so not sure on that one.
Focker
I have one 90 degree hook on the left side, I think it helps alot when cornering because you can lean out that much farther and still have good control on the bars. One thing I think I need is the extended brake lever though! I can get it under my cover but it is tight, if there were two hooks Im not sure you could get the cover on!
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
I have the 45 degree hooks on my 04 RX-1M. I love them and YES they fit under the stock cover. It is tight, but they fit.
J.
J.
Indy
Welt, I have one on my left side, I use it alot, but it destroyed my cover, I had extra material sewed into cover, then bought a covered trailer.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
I have them on both sides and the cover barely fits.
welterracer
Thanks guys..
