xrrider
I am getting ready to do the 128" conversion on my Phazer. I see that the extensions from Hartman are quite a bit cheaper than the ones from Tracks USA. Is the quality of Tracks USA that much better?
Thanks.
Thanks.
T.S.U.Filmz
You would be better off to go 136 128 is not worth it. Both company's have qualty parts. Hope this helps
Ps: you might want to add your location it is a site rule.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I've used hartmanns's on four sleds now it they still look new. The hold up for a long time and his tunnels look a lot nicer then the ones from tracks usa.
xrrider
Not wanting to extend the tunnel and bought a 128" track very cheap is the reason I'm going this route. Thanks T.S.U. for pointing that out.
T.S.U.Filmz
I understand not trying to tell you what to do just trying to help out.
tatalover78-2
I used mountain peformance extensions with built in offset. I believe they also have regular axle. Easy and excellent customer service
xrrider
T.S.U. I meant thanks for bringing the site requirement to my attention, also thanks for you input too.
tatalover, where did you order your extensions from? I don't see them offered on thier web-site.
tatalover, where did you order your extensions from? I don't see them offered on thier web-site.Thanks
LJ 452
I used the 128" Tracks USA extension (From Ulmer) on my S.E.. The extensions used both the stock axle slot and the slots in the rail located below the axle. Additionally the Tracks USA one's allow for full length hifax. I have put several thousand miles on the sled with no issues. I can't comment on the other brands as I do not have any experience with them.
tatalover78-2
just call them... their website is not the best but they have. I have been running their stuff for the last 5 years and never had an issues and they are awsome of tech and returns
